Moving consumer unit
3 Apr 2012
Cumbria
Hi
My consumer unit is in the garage, just above the main incoming cable. I want to move my consumer unit about 3 metres from the main fuse (tails etc.
What will i need to do this? and what size cable will i need to use, the consumer unit is a split 12 way both protected by RCBs.
3m is the max limit, so you could just use long tails
I would fit metal capping to protect them though.
Fun moving the twin and earth
Ok thanks, i didn't realise you could use tails that long. I will be boxing the cables in and they will be above head height, so shouldn't get damaged.
I will have a measure up tomorrow, to see how long it is.
As Andy says, do not forget that you will have to find a way to join, extend, or re-route all of the cables for every circuit that connects in to the consumer unit. DIN terminals on a suitable rail inside a large box might be a solution. Something like this http://www.cle-electrical.co.uk/c/142/din-rail-terminals
It needs care, planning and proper testing afterwards.
The supply tails are the easy bit - how do you plan to disconnect the supply, by the way?
Thanks for the reply, its a full rewire, so all new cables will be run in.
I will ask my electric provider to fit a new meter, as the one in is really old and makes a buzzing noise, so they can connect the new tails up then.
I will be getting the installation fully inspected and tested.
They wont connect the tails up. That is for your registered electrtician to do as a last part of the rewire and replacement of the consumer unit.
Are you planning to do this all yourself? Are you aware of the legal requirements re notification and lodging a Building Notice with your LABC? Registered electricians can only certify and notify work that they have DESIGNED INSTALLED and TESTED themselves.
