I am wanting to move our current electric oven around 1m away from is current position which means extending the current cable. The cable also currently goes down the wall on the outside via some cable clips tacked to the wall (which looks very ugly). The old lime plaster is falling off the wall and so we're going to strip off all the plaster and get it replastered (ie proper base coat wet plaster & skim, not plasterboard etc).
The electrics in the house are reasonable modern (the current cable is black and red) and it was done just before the new colours came in.
I have some spare unused electric cooker cable thats exactly the same colours and thickness and wondered:
1) Can I join the cooker cable using an appropriate connector in the floor boards upstairs and then feed a new cable from that down the wall to a 35mm metal back box and cooker cable outlet plate ?
2) Am I ok to hide the cooker cable (covered by an appropriate plastic trunking cable) behind the plaster ?
Does this have any part p implications ?
