Hi guys,
Im renewing my kitchen and need to move a couple of sockets.
The first socket i need to move needs moving 10inches to the left of its original position. Thee wires enter the socket from directly above and there is no slack wire.
Is it ok to joine a length of wire to the existing wire using 30amp connectr block which would then be taped up and sunk into the wall with the wire then running horizontally across the wall from the old position to new position??
the secound socket i have needs to be moved approx 1m down the wall from its original position. again can i just add a length of wire (2.5mm) and connect via a connector block??
i f i cant do this guys, can you tell me how it needs to be done
many thanx in advance
