I've asked our local operator to change my overhead supply cable to underground.
It's a tough process due to staff shortages. I don't need the meter to be moved, so I asked for a quote for them to
The quote I've received seems too cheap based on what I've heard (£600), and fairly non-descript. I have a couple of pages of small-print, which seems to imply that I do most of the work (dig trench, fit 32mm ENATS compliant ducting with draw string, etc) and they just connect a cable. Does that tally with the experience of others on here?
This is fine as long as I know what's expected of me. Lots of talk of hockey sticks which I think it only relevant if I'm moving a meter, and they seem to stipulate that an electrician needs to be on-site, but I'm not sure if that's only a requirement if I'm moving my meter?
Could anyone confirm:
- trench across 6 metres of concrete covered drive so that the new cable would pop-up in the garage,
- clip cable up the inside garage wall, then through the wall to the existing meter on the other side.
- The customer (and their builder) always does the trenching/ducting and making good.
- Having an electician on site isn't required for a simple supply move.
- They'll be willing to clip up a garage wall and aren't going to arrive then refuse to do the job because I need to trench all the way into the room that has the meter?
