Hi, we are thinking of moving from a vented cylinder to an unvented model. The reason for this is that the pressure in our house is extremely low (not the mains pressure which is > 3 bar I believe) and this has for many years been boosted by a pump. The pump has broken down (goes off the whole time) and is also extremely noisy so am looking at this as an upgrade rather than just replace the pump. I have been quoted approximately £2,800 + VAT (in London) to remove old cylinder, tank etc. and relocate unvented in loft. This includes pressurising the existing heat system.
Will the unvented system give as much pressure / output as the pump did?
Does that sound reasonable? This is a G3 plumber who I have used on other jobs so trust but wanted to understand if that is around the right cost. He said would be probably a Telford or similar tank. Thanks
