Hi all,
First off, I don't intend to do any work on gas stuff myself. It will all be done by the appropriate people - registered plumbers or the DNO as appropriate.
I need my gas meter moved.
The currently arrangement is that the metal (steel?) pipe comes through the front wall of my cellar (about 2ft below ground / 4ft above the cellar floor), along the wall about 2m in a straight line, through no obstructions, goes into a shiny flexy pipe with a valve, then into the meter.
The perfect solution for me would be to have the meter moved about 1.5m towards the wall - i.e. remove 1.5m of metal pipe and put the meter there. Exactly the same height as it's at now, just literally cut off 1.5m of pipe. Really really simple - no hacking holes, no rerouting pipes. That would be, for me, the perfect location. Easily accessible but not in the way.
I had SGN out to quote and the guy immediately said they can't connect to that metal pipe. Solution: fit a new (outdoor) meter housing about 3m along from the old point of entry (only place it can go), dig up the drive, divert pipe (join onto old one, I presume), get new meter (old one's not suitable), pipe from there into house about 3m from where it needs to be (and the wrong side of a wall), load of internal plumbing to get the new gas pipe to where the old one was.
Problems with this are:
1. I'll need a load of pipes routed around inside, which is a pain.
2. I'll need to get SGN to move their pipe and install new box, British Gas to replace the meter, and my plumber to do all the indoor routing, on the same day, or have no gas. That's almost certianly not going to happen.
3. It's £600 just for SGN. So, what, £1000+ total I expect.
The meter needs to move, and if I have to go through the above then...well...I have to do it. But really - the PERFECT solution for me would be to move it 1.5m back down the pipe it currently is. It just seems like a lot of time and hassle and expense and extra pipework, when the perfect solution is just so so simple.
Does anybody know why they can't connect to this metal pipe? Why can they connect it outside and not inside? Is there a way I can get around this? I don't want to do anything "naughty" - I want a nice safe, legal way around it. For example could they push a plastic pipe down the middle of the metal one - something like that? A company other than SGN who perhaps will see things differently?
I presume the metal pipe is their pipe. Is there something I can say which will get them to replace that with a pipe which CAN be joined?
Another solution - if they're digging up the drive anyway - and if for some reason I can't think of it's only possible to join to metal pipe outside - would be to connect the new (plastic?) pipe there, and route it back into the same hole the old one came out of. Same meter, perfect location, no new holes. And EVEN IF they charge the same amount for that, it's a better solution from my point of view.
Sorry for the long post and thanks in advance for any help!
