I'm in the process of getting our hot water storage cylinder moved into the loft to create space in the bathroom. Eventually we will also be adding a pump to provide higher pressure showers.
My question is, would you recommend that I ditch the current tank, which is, 36" x 18", and swap it for a larger one? Is 42" x 18" the next standard size up from this? The house is a 3-bed 30s semi.
Thanks.
Thanks.
