Moving PIR's?
20 May 2009
I have a secuit 700L system and I need to move two PIR's.
How do I isolate them in order to disconnect them to move?
I have tried isolating the mains and backup battery but the alarm siren outside still goes off?
Any help hints appreciated
Open the panel lid and enter your code when the internal sounder goes off.
If the wiring is labelled, find the cable(s) that go to the two PIR's and disconnect them from the 12v terminal. You should now be able to move them without a problem. Just remeber to reconnect the 12v terminal when you're done ;)
Is that the Aux cables?
