Hi all
The ceiling light fitting in my front room is in the centre of the room, but I would like to hang a pendant light over a table approx 1.25m from the central fixture.
I'm not keen on the idea of having conduit running across the ceiling and even less keen on the idea of gouging into the ceiling to run cables through. Ideally I would like to place a hook above the table and have the wire on display running across to the hook and then down to the light. Is there a fitting you can buy that takes the balances the weight between the looped cable and the drop to the lampshade?
The reason I ask is that nobody seems to do this in the UK, although it's extremely common in Scandinavia (example here: http://boligmagasinet.dk/article/87254-hjemme-i-stylistens-designparadis/gallery/569798)
Any advice very much appreciated!!
