Moving shower pump
Bon
4 Jan 2007
Lancashire
Hi there.
We installed a shower pump a couple of years ago. I put it in the airing cupboard at the base of the hot water cylinder.
The bedroom that the airing cupboard is in has now become our new arrival's Nursery. In a few months he'll be in there sleeping and the pump activating will no doubt wake him up in the mornings (I get up at 5am to go to work) and I don't fancy going back to gravity showering (i.e. running around under the dribble to get wet!!).
The cold feed and cold drop down from a cistern in the loft to the base of the cylinder, cold feed enters the cylinder and cold goes to pump inlet. Hot comes from a York flange and to the pump inlet. Hot and cold then go back up into the loft, traverse across and then drop into the shower cubicle.
In theory the system gravity flows without the pump, so anywhere along the line would work, provided I don't lift the pipework above the level of the water in the cistern.
Just wondering if you guys had any suggestions/experience of where the second best place is to locate the pump as I want to get it right first time!
