The house we are moving into has a galley kitchen (3.75m x 1.9m), the galley is so narrow that we are going to put a new kitchen in and only place units on one side. Unfortunately the sink will need to move to the other side of the galley (about 1m). My problem is how to get the hot/cold water and waste across the galley. The floor is solid. Is is ok to chase in a channel into the floor and cross in this way?
I read on the forum that a 1:40 drop is needed with a 40mm pipe for the waste and you need to insulate the pipe work before covering the pipes with concrete. I guess I will have to be careful of the DPC....
An alternative would be to route around the side of the room but there is a door in the way.....any ideas?
Thanks for help.
Thanks for help.
