I want to move a toilet and install a bath.
This is a picture of the end of the bathroom.
On the left are the existing toilet drain and air-inlet vent. I want to place a bath against the wall on the left and a toilet against the end wall to the right of the bath. The end wall will have 70mm of PIR insulation on galvanised battens. I hope to run a new 75mm vent pipe (BC specified size) up behind the plasterboard on the end wall.
This shows the soil pipe on the left and the vent on the right.
This is a detail of the vent showing the bend.
There is roof space above where the current air-inlet valve is situated and there is another flat downstairs, so I cannot alter the soil pipe below their ceiling.
Can I run the toilet drain under the floorboards where the vent currently is and bring it up in the corner? It could then run under the sloping end of the bath and out through the bath panel to the new toilet position.
It would be nice if I could run the bath and basin drain into the soil stack. Currently the old shower and basin drains run out through the wall to a collector.
edit: original post subject didn't attract attention
