Hi, can anyone help me?
I've just bought a house which has a front living room and a rear living room, there is a light in each which is controlled from one 2 rocker switch in the hallway.
I want to separate the switch into two 1 rocker switches in each room, so the switch in a room controls that rooms light only....
when i've looked inside the existing switch casing there are only 3 wires (all black) and one black wire which links to both common points.
Can anyone give me any advise that is simple to understand and not the equivalent to a rocket science degree????
Thank you.. Mark
Thank you.. Mark
