I think I already know the answer to this one but I will just confirm for my own peace of mind!
The scenario- a large lounge with 3 wall lights and a dimmer switch (standard config) The position of the two wall lights on the far wall is pretty pants and therefore both need shifting 12 inches (one to the right and one to the left). The walls are dry lined dot and dabbed over aircon blocks. The ceiling is going to be skimmmed over to get rid of horrendous artex stipple but the coving is to be left in situ.
Now I know that the correct and logical procedure is to make a dirty great hole in the wall, coving and ceiling above where the existing wall lights are and then run new cables from junction boxes in the ceiling to the new positions..... BUT
the wife doesn't want me to do this due to work/ cost implications so the other option I have considered is running a 12" horizontal spur from the existing positions to the new.
I would chase out the aircon block to bury the spur cable 2 inches and then place a 8mm steel rod in front of it for protection. To protect the spur connections in the existing architrave box I was going to put a blank plate over it. Obviously the wife is NOT HAPPY with the aesthetics of this, so can I wallpaper over the plate and still be compliant with existing regs or is this a big no no?
Ideally I'd like to plaster over the plate but this then negates the visibility aspect and access for maintenance part of the regs I presume?
Any advice apart from getting rid of the wife is gratefully received!
