Moving wall sockets
7 Apr 2009
Hertfordshire
Hi, I wonder if there is a qualified electrician who can help with the following.
Rather foolishly, we finished decorating a room and laying new wooden floor, before deciding we wanted to replace the older skirting with a deeper one - consequently we want to raise 3 wall sockets to accommodate this.
There is enough slack on the cable to one socket to raise it as necessary, but the other two are too tight. Is it permissible to join/extend wires inside the gang box, either using terminal block, crimping, or by some other means?
Obviously whatever we do will need to be inspected and we want to be fully compliant with current regulations.
Any advice would be really appreciated.
Many thanks
Norman T
Yes it is permissible to join cables, I would reccommend crimp connections and you should only use ratchet crimping tools ( not car tools) then heat shrink sleeve over for protection.
Many thanks for that - I assume that's the simplest way to proceed then.
Note however that the grey sheath must still enter the box!
If the cables won't move in the capping, then take the plaster off under the skirting and take capping off and see if you can then get enough slack
No idea how you ae going to do the job without messing up the decor though, granted if you are careful you can chop a box in without damage, but how are you going to cables to it?
