Good afternoon all,
I building a posh garnen room with bathroom in the back of my garden, 40m from the house. The house is on a shared water main galvanized pipe and from there it goes through a softener all basically 15mm copper pipes. I was planning to connect the garden room after the softener. I was planning on using 25mm MPDE pipe.
I just had the builder around who is doing the trench and ground work and he said I should use a MPDE pipe as due to the bigger pipe I will have not enough pressure.
Question is I'm i correct in using 25mm pipe or should I be using a smaller pipe, my understanding would be the smaller pipe has more resistance and that would mean less flow, even less pressure.
Thank you.
Thank you.
