Took the actuator off today, the spindle would only move mm's either side. I applied some WD40, it moved a little. I dodn't want to put too much pressure on, as I do not want to snap it. How stiff should this spindle be?
When I put the arm to manual, the lever has to be right over to kick the pump into action, by the time it has gone into it's slot (the "M") it switches the pump off.
Also, how can I check the actuator is working properly, I mean if it is off the spindle could i still get it to actuate, to see if it works?
Thanks in advance.
Thanks in advance.
