I've recently bought a house which is in need of a restoration and I need to chisel off a few walls of old plaster from brick and I also need to chisel a few bricks that are covering an old fire place which I wouild like to reopen and use again.
I have looked at a few SDS hammer drills with chisel function but there are so many different specs to choose from and i'm worried about buying the wrong one for the job in hand :-/ I am confused about the different weights 2kg - 9kg and which wattage drill would be adequate enough to do the job. I would like to spend no more then £150. I rang screwfix for advice but apparently they are not allowed to give me advice for whatever reason...?
I would be most grateful if someone could recommend me on the type of spec chisel drill to use or even a model of drill within my budget please???
thanks in advance guys
