Multi fuel Flue Advice
1 Apr 2006
Hi All
I am putting in a log burner to cut down on fuel bills and need some advice.
(I will be getting it all checked out by local building inspector on completion, so will all be safe - and already bought co2 monitor)
I have opened up an old chimney and plany to line with flexi liner which will terminate in my attic as stack had been removed.
I will use a lead slate to bring through a rigid pipe and terminate this just below the roof (which will give about 500mm above the slate - the rain cap will be about 200mm about the roof ridge)
What I want to know is, will a 5" liner be ok (twin walled) or does it have to be 6" (Its a 5kw log burner)
Also, does the final length of rigid pipe have to be twin walled??? The flexi liner will be around 7 metres long, so was hoping to use 6" vitrous pipe through the slates as it looks less cumbersome than the twin walled pipe.
Hope I havent missed anything for someone to give me a nudge in the right direction!!
many thanks
Rhys9918
I am NOT HeATS, but we sell SF and have a HETAS guy fit them. So:
SF is expensive and labour intensive, so unless you have a reliable long tern source of fuel (and freee time), you wont always save anything. Woo must be seasoned 2 years, and oak should be kept OUTSIDE 1 year before that
you must inform LA BEFORE commencement
Beware, there are specific minimum clearances. These are two hand in my shop, so I havent bothered to memorise
Some are. You must follow makers instructions, and they differ
You CANNOT use flexi outside of a brick flue. I THINK you now have to use insulated twin wall, which is expensive.
