I live in a 4 bedroom house with a gas boiler (Stelrad Group Ideal Mexico) powered central heating system. Downstairs is fitted with low level radiators and upstairs with slim solid radiators (no fins). The boiler is 30 years old, but has been serviced regularly by previous owners. The downstairs radiators are particularly poor at emitting heat and upstairs only marginally better.
The main room has a gas guzzling fire venting up the chimney and the hot water is supplemented by 2 solar panels fitted around 1985.
I'd like to remove the gas fire and replace it with an enclosed wood burner. Looking on the internet you can get a wood burner that heats the hot water and can supply a couple of radiators for a little bit more money. Is it technically possible to have a system as follows; hot water powered by solar, wood burner and/or gas boiler; central heating main bedroom and living room radiators powered by wood burner or whole system powered by gas boiler. Assuming it is possible, any thoughts on maintenance problems or running problems caused by the increased complexity?
