Multi tool cutter for concrete
28 Aug 2020
Hi, just wondering if anyone can recommend a good multi tool accessory that cuts through concrete for a DeWalt? It’s for places my angle grinder cannot reach. Thanks
Pretty sure they don't exist.
And not needed in any case.
none that will work
a buzzy toy the the blade will move perhaps 12mm side to side x say20000 that is say 240'000 mm per min
a 115mm grinder say 11'000 revs x345 =3'795'000mm or around 160 times more distance:D:D
you can get diamond half-moon cutters that are useful for trimming tiles. I don't know how long they would take to go blunt on concrete.
I used one to cut a plastic pipe embedded in mortar, and it sliced through the mortar as well.
I find the brown slitting wheels break too easily.
More info required , multi tools tends to have just as little reach as a grinder.
What concrete could possibly need cutting with a multi tool, and be in such a place where no other tool (such as a chisel) won't suffuce? o_O
some awkward corner? In the same way that a multitool is handing for trimming off the last of a floorboard when the circular saw won't get any closer?
I had to cut a square hole in a concrete wall once.
Perhaps someone should invent a metal thing, with a bit of a tapered sharp end, and a flat end that you hit with a hammer? I reckon it could be a winner!
Can't see that ever catching on, Woody - it isn't powered by a nuclear power station
