Hi im new to the forum and would really appreciate some advice. I have laready tried searching with little or no luck with what im trying to do. I live in a small two bed cottage which has no central heating. The heating is currently provided by an aged 6kw hunter woodburner. this is shortly to be replaced with an 11kw multifuel stove with back boiler. My hot water is provided by a boiler in the attic and so i have no emersion tank. The back boiler on the wood burner will be 3kw. What i am looking to do is run a completely seperate gravity fed system e.g. with no central heating pump and not in anyway connected to my existing hot water system.
My thinking is that as the system is only 3kw 10.5 btu that it should self pump. there will be an expansion tank in the attic. Is this system workable? i have spoken to a couple of people, one who runs two radiators on this type of system and another who runs his with a pump but seemed to think i could do it unpumped.
I understand that i should not use TRV's with this type of system either. Essentially i am looking to install the simplest possible 3 radiator heating system possible.
Also i am intending to do this using 15mm piping, my understanding is that for heating under 4.5kw 15mm is perfectly suitable. is this correct?
Any help/advice greatfully recieved.
Blister
Blister
