This has probably been answered so many times over but....
Moved into a property with plasterboard walls in the lounge and an 'open plan' stove. Not encased, but situated with exposed flue pipe, and the required measurements away from wall. Have concerns about the plasterboard wall which can be very hot to the touch. We have no idea if the plasterboard has been replaced with fire-proofed board, though there are heat cracks running from either side of the hearth, up the walls, where plasterboards been joined together.
We dont fancy ripping down the plasterboard to check, would drilling into it give us some indication?
also, we were considering a heat proof 'splashback' similar to what can be mounted on kitchen walls behind hobs, wondered if there was a similar product to be placed behind a stove?
any suggestions are most welcome, thank you!
