Hello
I recently got some help from here so am trying again
Having had a couple of quotes from firms to install a multifuel stove with boiler I've been given conflicting advice and would be grateful if anyone could help.
The stove is required to heat the room (11ft x 18ft x 8ft high) heat the water and 4 radiators. Eventually I hope to add another 3 rads but can't do that now.
HETAS confirmed that I need an output of 2.8 kW for my room size.
Firm 1 recommended a Hunter Herald 8 for the job and Firm 2 the Arrow Stratford Eco-boiler SEB 20.
Now the problem... according to the technical blurb the Herald 8 supplies 8.5kW to the water(29000 BTU) and 2.5kW to the room.
The eco seb20 supplies 12kW to the water(41100 BTU) and initially 8kW to the room. The blurb advises that once a certain temp is reached it then goes to slumber mode and will give around 2kW to the room so they recommend that a radiator is also installed into the room.
Firm 1 says the eco boiler is far too big for my needs Firm 2 say it's perfect and I don't need the additional radiator. Neither Hetas or Arrow could advise.
Can anyone give me any advice please? Don't want to fork out for the wrong one.
D
D
