Hi all,
I'm looking for a bit of advice on designing multiple new waste connections into an internal soil pipe.
I'll have 3 wastes (sink, shower, bath) that I want to join into a single 50mm pipe (running at a slight downward angle on a horizontal. The 50mm pipe then connects into the internal vertical stack.
Is this the right way to do it? Can I have that many connections into the 50mm pipe. I assume that 50mm pipe is the right choice for that run? Do I need a particular type of trap on the sink, shower, bath if I do this?
Finally I'll also have a 110mm connection into the stack for the toilet also. The 50mm pipe described above will connect around 200mm lower into the stack than the 110mm connection for the toilet. Presumably that is OK?
Many thanks.
Jon
Many thanks.
Jon
