The property is Victorian, over 3 storeys high with 2 capped and unused chimneys at this level with the third at first floor level.
There is damp causing problems internally on and around each chimney breast.
Measures taken so far include flash banding the base and coping stones of the gable end chimney and flash banding around the base of the other high level chimney. Also cracks in between coping stones and chimney caps have been cemented. These repairs have made matters worse.
Are new lead cappings and soakers necessary as well as patch pointing and silicone spraying of the chimneys or is replacing the lead flashing around the chimneys + pointing + silicone likely to be sufficient?
Finally is there a way to minimise the need for frequent gutter cleaning considering the height of the property?
