Multipoint water heater service
19 Aug 2004
Our Britony IIT (about 10 yrs old) doesn't fire up unless the hot tap is opened almost fully. It's always needed the tap to be opened most of the way, but I've just put in a new kitchen sink and monobloc and it splashes too much with hot tap that far open. Should this be fixable if we get it serviced? And generally, is there likely to be any justification for the service engineer saying the whole thing needs replacing? Just want to be prepared!
eek britony 2 t ,if the engineer services it properly it should work again, but it sounds like the diaphram may be going its not terminal but can be a bugger to reseal when you put it back together
No matter how good a sevice is done it won`t fix it ,A new diaphragm is required part approx£10
the manaul recomends that the diaphram at a service is changed at least every three years (proper service) :)
