I'm starting on a new build, aiming for high levels of air tightness and insulation and I've a question about MVHR and the traditional method of engineering the structure to be slightly leaky..
Is MVHR any better for heat retention and heating running costs than a trickle vented house? Let's say there's MVHR system that recovers 90% of the heat in the exhaust air and heats the inlet air with it... This house loses 10% of its heat continuously, right?
Now, if the house leaked a little air, that would be warm air, being replaced by cooler outside air which will need heating.. So conceptually we might need to put the same amount of extra heat into our leaky house as we put into an MVHR controlled house, so what's the point of MVHR (other than you can more rapidly freshen all the air in the house without losing all the heat) ?
If the MVHR system cycles 100 cubic metres of air in the house per hour, then is that the same as having a house that leaks 10 cubic metres of warm air per hour?
And, if 10 cubic metres change per hour was sufficient for regs, is there any point to installing an MVHR? Is a house where the air change rate is 10x higher a more healthy place to live? Essentially, just wondering what the compelling arguments for MVHR are?
