Hi, i have a 6 month old ferroli f30b. The problem is that its basically pot luck to get hot water from the boiler: the symptoms are as follows which again dont happen all the time and neither do they occur together:
1) the boiler will look as if its going to fire up for hot water even though theres no tap on, it wil click and the tap light will momentary come on.
2) when you turn the cold tap off the boiler will click, heating goes off and the boiler tap light come on and momentary clicks to fire up but then goes off.
3) for no apparent reason, the boiler will click between heating and hot water, again there are no taps on in the house, it will click over 3-4 times.
4) when the heating is running and you turn the hot tap on, the heating will still run so you get luke warm water from the tap, obviously when the heating goes off, the tap goes cold (note problem 2 doesnt happen when this one does)
5) you can turn the hot water on and nothing, no clicks or anything no hot water, just comes through ice cold (doesnt happen when problem 2 does)
Ferroli have been out and sods law, it workes great when they were here, but one day on its up to old tricks.
Ive tried to give as much detail as poss, but please ask any questions.
I would like to give thanks for any contributions in advance.
Andy
Andy
