Hi there
Last February i brought and installed myself a Gainsborough 9.5kW electric shower to replace the old and crumbling 8kW one that was already in place. Its worked fine til this morning...
When i turned it on it immediately started spluttering violently so i quickly turned it back off half thinking it was going to explode in my face. When i turned it back on and every time ive tried since the water fails to warm up at all.
At first i thought the heating element had just burnt out but the flow control seems to have stopped having any affect too. Before on its coldest setting it would give a lot of pressure now its just a little more than a dribble whatever setting i use.
It was working fine an hour before this happened. I know it is receiving power as the light on the pull switch is on (annoyingly theres no indicator on the shower itself) and water pressure seems fine around the rest of the house.
I am going to call customer service when they reopen on monday but i was wondering if anyone here has any suggestions as to what the problem might be and if i could fix it without outside help?
Thanks for your time
