I'm going to build a cupboard in the alcove next to the chimney breast. Having previously done similar things in MDF, I decided it was time to try my hand at something wood-only.
I couldn't find any boards made of softwood wide enough to use as the uprights of the cupboard, so I bought 7cm wide planed planks at B&Q. Also bought a dowelling jig, so over the weekend I'll try my hand at putting 5 boards together side-by-side, held in place with dowels and glued, to get a single wider board. I know it won't be perfect and that I'll probably have to plane any unevennesses (particularly since the planks aren't 100% flat, although they're sorta straight).
I have never had to glue wood before (only worked with MDF and those white plastic corner brackets that so often are used in flatpacked kitchens). But I understand that I'll need to drill dowel holes, put PVA on the sides of the planks and then press it all together.
Practical questions:
When I press the planks together, there will presumably be some glue squeezed out. On the top of the "board" I can wipe that off, but how do I get to wipe the backside of the board without moving it around before the glue has set?
Will the glue that gets squeezed out make the board stick to the floor? (or rather, to the tarp that I'll be putting down on the floor while I'm gluing)
It says on my tin of PVA that it sets in a couple of hours and is solid within 24 hours. Does that mean I need to keep it clamped for 24 hours, or can I remove the clamps after a few hours? (I only have one set of clamps and would like to make two boards the same day rather than having to spend the whole weekend just making boards)
I've had a browse around the site. Looks like a great place. I look forward to spend some more time here
