What is the minimum clearance you must have between the ground and the underside of the deck?
I am planning to put decking over a solid, but uneven existing patio, however do not want to raise the level any more than I have to. Would I be able to build the frame using 50mm by 50mm for example?
Any help/guidance gratefully received.
