my heating isnt working
12 Sep 2005
Yorkshire
hi we have a back bolier so wen heating n water come on poilet lite flares up, the water is working wen u turn it on poliet flares up, heating isnt doing anything...andnot heating radiators either is this a big job does any 1 no, the swithc is coming on to click on radiators there just arnt lisax :cry:
pump it sends the water round the heating
as for where it is prob near the boiler under floor or in the side of the chimmney breast ;)
oooohh second morgage time :LOL: :LOL: ;)
might only be stuck
if you can find it unde the screw marked belld and stick a screwdriver in the hole and turn the shaft ;)
im guessing mine is behind my fire and i aint about to take the fire off wall, as wouldnt no how to.... i have seen the pump before just cant rememeber were
no im not about to be that silly iphoned a loacl plumer just wanted to no if any 1 knew if it was a bg job and how expencive as we in middle of selling house thak you for your help lisa
If pump just needs a poke to get it going it's just a call-out, if needs replacing probably about £120, depending...
Sometimes the pumps are under the floorboards to one side of the fireplace. Bad news if you have laminate floors!
hi if it was the pump would that not make my wter not work too as poilet is firing up for when you put water on, it just not doing anything when you put heating on
arrah it seem that now my water isnt working either well its not making the poliet flare up im thinking big job now lisaxx
