My heating wont switch off and my water wont heat up unless
10 Mar 2009
Cheshire
My house is 4 years old. I have an ICON boiler and have recently noticed that when i have the heating switched off or on timer the heating is still coming on. The boiler is still firing up and the radiators still on constantly, even when the thermometer is switch right down to nil. The only way i can switch the heating off is to actually switch the boiler to off on the wall or on the boiler is self. I bought a new timer programmer, exact same on as was previously fitted but i am still having the same problems. Does anybody have any ideas what is wrong? :( Also the only way i can get my hot water to heat up is if i have the imergion switch on - it wont heat up through the programmer.
check all wiring in the wiring cntre is correct and tight (turn supply off first though/remove fuse).
could be a 2 port motorised valve sticking in the open position (if you have them) (but with the stat down it shouldnt come on like you say)
with the new programmer - did you remove any links from the back (to allow it to work for a fully pumped system: i am guessing you have a fully pumped system)?
or a 3port stuck in the heating position
no hot water, constant heating ;)
I'm assuming the boiler is a rebranded Glowworm Ultimate, as thats the only heat only boiler that I'm aware has Ikon branding
