This only happened today. Does anybody know why??? I've checked the fuses etc... but as soon as I plug it in it trips everything out on the ring. Also there is a full load inside and need to get it out. How is this done with no Electricty
It might be a faulty door switch but there are various other possibilities, one being a motor fault. To eliminate the motor as a suspect you can unplug it from the wiring harness and see if the machine still trips. To get the washing out you can drain the machine by gravity. Disconnect the grey waste hose from your house plumbing and put the end into a bucket at floor level to drain out
