Hopefully my final topic on my impending upgrade from a Scantronic 9800 to an ION-40 is about my external sounder.
The sounder was fitted 20 years ago & I have no idea of the make as I have a white bellbox with the alarm company logo on it. The internal battery is pretty bad, when I remove the 12v line at the bell box I get quite a feeble noise from the bell. However the bell box will be my summer project so I will reuse it for now & do not intend to climb up to it.
I will be without a working panel for a couple of days, is it better just to let the sounder ring until the battery dies or is it better to rig a 12v supply at the panel end to keep it quiet for a while ?
The current sounder has 5 cores at the panel end which connect to the 0v, 12v, TR, Bell & Strobe.
I am happy how to connect the 1st 3 wires, however the specification for the 9800 says:-
Outputs OP1, OP2, Bell, Strobe = 500mA. Transistorised outputs capable of driving a relay. The Bell and strobe are set as negative applied in alarm.
The ION-40 has outputs 1 & 2 as voltage free relay outputs and 3 & 4 as transistorised outputs 0v when active and 12v when inactive.
The recommendation for the new box is to connect the sounder to the Normally Open terminal of output 1 and connect the common terminal to aux 0v , thus giving 0v in alarm and an open circuit normally.
I therefore seem to have an option as to whether I connect the bell trigger to Output 1( 0v active ; open inactive ) or Output 3( 0v active 12v inactive).
Does the difference actually matter ?
