Right,
I have a wet patch on the ceiling in one of the rooms, as well as a patch on the outside wall in that room, with some water dribbled down. Quite a big wet patch on the ceiling that looks like a shadow, but the plaster hasn't sagged or anything (yet). There is a thin layer of loft insulation above the plaster.
I moved into this Victorian mid terrace a few years ago and had a company called "Everlast" out to do some jobs on the roof - gutter, repointing ridge tiles, replacing tiles where necessary. In my opinion, they are a cowboy company; did a shoddy job. Charged over £700 and didn't seem to do a lot. This was over 2 and a half years ago.
I have since had other roofers look at it (I was after quotes as I was planning to move house at one stage). Nobody ever quoted anything more than £300 just to replace some tiles, etc.
The general view seemed to be that the roof is old but in decent condition for what it is - just needs some little bits doing.
But now I have this wet ceiling and wall. I got a guy to come out and look a few weeks ago and he quoted £300 odd to replace tiles. No doubt having roofers up there has made matters worse as they climb all over the thing.
Is this really the solution I need? Just endlessly replacing tiles here and there!?
I've been looking at roofbond. www.roofbond.biz
They spray a bonded chemical on the inside of the roof that (allegedly) bonds the roof together into a stronger roof that doesn't leak. This would cost approximately £1600
Having the house re-roofed would cost god knows how much - £4000?
I keep seeing people on these forums dissing the roofbond solution. I just want to be sure that this isn't the traditional roofing lobby slagging off a competing technology...? One of the criticisms is that it traps moisture which rots the wood in the roof - but roofbond say they install soffit vents. Also, it is said that the roof will be harder to fix later - but roofbond give a 30 year guarantee (and have been around for 40 years.)
Any thoughts?
Has anybody used roofbond?
Any thoughts?
