My washer-dryer trips out my fusebox.
11 Oct 2008
Devon
I have an Ariston Margherita AV1247C washer-dryer which I was given with no manual, although using a washing machine is usually fairly straightforward! But sometimes when I use it I end up with no electrics. It only happens as/once the wash cycle has finished. The dryer is set to 0 so it doesn't come on. It is not blowing the fuse for the kitchen, but tripping the overall switch for the house, which I then reset. Is there something I should know about the position of the dryer dial when not required? It only happens when the washing cycle has finished. I did once use the dryer, without a problem. By-the-way, the problem only occurs sometimes. On other occasions I use the machine without incident, either during or after. Can you help me? :confused:
no not really :cry:
its intermitant it has an earth fault somewhere, it needs to be checked by an appliance engineer with an insulation resistnace tester
this will identify what it is that is causing your RCD to trip
it may be as simple as the motor coveredin carbon, it may be this that or? without seeing and testing its not possible to say, only guess
take the lid off and see if theres a wire loose near the heaterbox or a cut wire touching the cabinet
Good idea. Now you mention it, I do remember that the top came off while it was being moved. Maybe something got pulled? Unfortunately the machine is pushed firmly under the sideboard in the kitchen and I can't budge it. Ill have to wait until I can persuade someone big and strong to come and pull it out for me so I can look. I'll let you know what happens.
Thank you for replying! :)
