Hi there, I have a Myson Apollo 30B boiler which has suddenly stopped working, I’ve noticed in the past that occasionally it didn’t fire up straight away when turned on, but have never had any other trouble until now.
I have a fully pumped, balanced system.
It seems to only fire up when the boiler is cool, the 3 position switch clicks into position supplying live feeds to both the pump and the boiler simultaneously, however the boiler will cut out after a short while, seems to be directly related to how cool the boiler is to start with (it does this on both high and low settings), even though there is still a live feed supplied (checked at the multi block connections behind the high/low thermo switch), the pump continues to run and is working fine. I think that it may be the thermostat??? How can I test this?
Can anyone help please?
