Myson Apollo 30si CH not working
30 Oct 2007
Cleveland
in the last few days the CH has started to refuse to light up. The HW works fine, but even when I switch boiler to CH & HW, the CH doesn't work.
Any ideas what it might be so I don't get over charged by the engineer?
Could be a problem with either the motorised valve or room thermostat, when you turn the heating on check to see if the valve motors open.
James
The room thermostat is on full, but as you say could be broke.
Re the valve, I can't hear the boiler do anything when I switch the CH heating on.How would I check if the valve was openin?
Any ideas how much either would be to sort?
ta
Do you have an airing cupboard with your hot water cylinder in.
Should either have 1 3port valve or 2 2port valves, in theory depending on system.
James
Right, got my hot water cylinder with my thermostat on (set to 70). Where abouts would these valves be?
Thanks for the assistance btw.
Mate you are a god send. I had been fiddling around outside near the boiler. Had a look in the airing cupboard and found a box saying auto/ manual. Flipped it over to manual then it slid back to auto. Tried the CH and it fired up first time. w00t, I'm going to enjoy the tropical heat.
Me again. The valve is the issue. CH worked fine so set the timer to have it on this AM. It didn't come on and I had to use the manual/auto switch and then it went on fine.
If I am going to open up the valve, what should I be looking at inside to check?
What type of valve is it, I,e Honeywell etc.
Normally easier to change the acutuator (head), than try and repair the unit.
James
it's a mid-position valve and I think it says Danfoss on it ( difficult to make out)
