Just moved into a new house and it has one of these boilers (myson apollo) in it with a dial timer that you pull.
Its a dial where you pull tabs and it has a thermoastat on High & 0 & Low.
Does each tab that you pull set a start and stop point or does it amount to 15mins of time ? Does pulling the tabs mean it on or is it when its not pulled that it means the boilers on ?
Also does it need to be in a high / low thermastat setting or can it be left in the 0 setting ?
