Myson Apollo Control
9 Jan 2004
We are renting the flat we are in right now and the boiler in the flat is called Myson Apollo. We did not find any manuals for the boiler. Could anyone tell me how to set the control/timer of this boiler. What are the different coloured numbers 1-4 around the 'dial' stand for? 1=red, 2=green, 3=yellow and 4=blue.
Appreciate any help as we want to set the timer..
Regards,
lipery
you will have to "play with it and see" it sounds like a common mechanical timer, one number is on the next off the 3rd is on the 4th is off
moving the numbers to the apropriate time tells it when to come on or go off.
so for argument sake
red is at 07.00 green is at 09.00
it will come on at 07.00 and go off at 09.00 (similarly for the other 2)
that is assuming you set it to the correct time in the first place, there should be an arrow/ indicator/mark that says time, turn dial CLOCKWISE so the the time when you do it is next to the mark
thanks. there is also another switch on the left side that says 'Once', Twice' and 'Cont' (continous?). Does this have to do with the timer setting or something else?
it means do you want it once, twice or all the time (never off) the heating / hw that is
