my friend has a myson appollo which needs replacing possibly with a potterton would a lot of wiring / pipework need changing as its going from b/f to ff? ive been told lots of wiring would need doing?
every body always wants to replace a boiler with the cheapest possible option, bet your friend drives round in the dearest possible car
they can still put in a more expensive boiler and make the new purchaser aware of exactly what he's/hers fitted never know they might feel more comfortable {as no expense spared etc} purchasing there house as opposed to someone else's.
As the apollo is already fully pumped there should be the minimal of pipework alteration also wiring should not need anything new run to it as it already has a permenant live neutral,earth and a switched live and pump wired from it which should be sufficent for most new boilers.
