myson boiler
1 Sep 2004
Not long moved into our semi-bungalow and I have a myson apollo wall mounted boiler, fan assisted flue, but no obvious indication as to the size (btu's) will it be "hidden" somewhere else on the unit? ---
information should be on the brown panel of the boiler it should slide out,ie stand in front of boiler and pull panel towards you,info stuck on inside if i remember correctly.
the bottom tray slides off forwards...have a look at the model number then ie 30/50, post it back here and we can tell you the output.
or failing all that u could gas rate it depending on the gas meter u have i am sure someone here will tell u how to do it as it doesnt involve anything to do with gas work
