Plumbing and heating novice after some help with the following -
Just moved into a new house (built 1997) with a myson water pump attached to a potterton suprima.
The water pump has started getting noisy, almost like a grinding noise which is keeping me awake.
I am going to bleed the radiators and the pump to see if this resolves the problem but short of that is there anything else I can do?
I don't mind getting a plumber in to change to pump if needed but would like to be reasonably sure that this is the problem before parting with the cash.
Thanks for your help,
RN
RN
