Myson Economist goes out after a short time of firing up
6 Nov 2005
Hi, i have a problem with my Myson Economist boiler.
I can ignite the pilot light no problem which stays on fine, but when i turn the heating on and the boiler fires up it only stays lit for about 2 minutes then goes out as well as the pilot light.
I have recently fitted a new thermo couple.
Does anyone know what the problem could be and would i be able to fix myself.
Thanks in advance for any reply
sounds like your boiler is overheating check your pump is working and you have water in the system :confused: overheat stat is linked to the thermocouple so if boiler is o/heating it would cut pilot out :rolleyes:
