(I have a HNC in Electrical Engineering, but I am more than a little rusty because I rarely do any electrics as part of my day-to-day job.)
I have just added a garage consumer unit in a new shed in the garden. The cable used is 2.5mm armoured and is contained inside an outer plastic tube. The cable is connected into the main household consumer unit using its own dedicated 20A MCB. In the shed, I am using an MK garage consumer unit (40A incoming RCD, two outgoing MCBs, one for lights one for sockets).
Using an electrical test meter, I get 240V at the input terminals to the garage consumer unit. If I click the incoming RCD ON, this 240V is passed through to both ougoing MCBs.
If I now press the test button, the garage incoming RCD does not trip out.
If I wire a brand new electrical socket into the outgoing socket-MCB in the shed consumer unit, I get power at the socket okay. If I now plug a device (any device, even something as low-current as a radio) into the socket and switch the socket on, the incoming RCD now trips out.
There are a couple of tests I haven't done yet (mainly because the weather is so bad), but I wondered if anyone could suggest what the most likely fault(s) might be here.
It all seems very odd to me. After all, basically all I am doing is connecting a single 3-core wire.
Any help or advice would be very gratefully received.
Kind wishes ~ Patrick
