Okay, this has been one of those days. I'm busy putting right what somebody else has done terribly wrong. The usual stuff; loop-in lighting confused by DIY light replacement. Anyhoo, here's the one that's bugging me.
Bedroom, two lights, two-gang switch. Turned power off, identified both switch wires with continuity tester, verified that the second cable from the second light was indeed the loop from the first. So, therefore the third cable into light number one must be the feed. Power on, check, correct. Sorted. To summarise then, light one appears to be standard loop-in/loop-out plus switch cable, light two appears to be the final one on the circuit plus switch cable. With all wires separated, of the three red cores at light one, only one is live, at line potential with every other possible combination showing zero potential. Lovely.
But here's the snag: When I connect this incoming live to the switch red only, not only does the remaining red (which goes on to light 2) become live, but so does its associated black core... and its earth. Now remember, I can see both ends of this cable and they are not connected to anything. Testing reveals a variety of voltages with respect to the neutral on the feed; 25V, 130V and 240V. At the switch all four conductors plus earths are live regardless of switch position. (The switch works perfectly well on its own)
The only explanation I can think of is that somewhere in that ceiling is a horrible short situation. Anybody got any other ideas before I take up the floor above (yes, it's a three storey jobby... no nice easy loft to poke around in!)
