Dear all,
I have a leak that I just don’t understand. I think the freeholder, whose office I am wetting, is going to take out a hit on me, or at least going to get legalistic, if I don’t stop it soon. Please give me your suggestions as to what it could be and/or what I should do to make sure it stops.
Background:
I’ve owned my flat for 20 years – first floor, 1980s build, concrete floors, office underneath. The bathroom was pretty cruddy, but no history of leaks. I had a new bathroom fitted 2.5 years ago, and the leaks started. It’s tenanted.
The plumber came back a few times and resealed the bath, refitted the waste pipes, changed the shower screen. After each visit the leak goes for a bit, then comes back.
I got another plumber and he did the same sort of stuff. He also found that the overflow pipe hadn’t been attached properly. Leak goes away then comes back.
This is what I know about the leak:
The only thing I can pinpoint is that some of the leaks happened when the tenants used the bath. They used to use the shower daily and the bath very occasionally, which may explain the sporadic part.
Now they have a baby and use the bath more, yet the leak is still only occasional. The last big leak (first for a while) happened again when they were using the bath – but why now and not other times?? It was a shallow bath for their baby. They didn’t use the showerhead and there was no super-splash-session .
The last leak was a big one, and also happened just after the offices had been refurbed so very embarrassing. I got the plumber/ builder back and asked him to remove the bath, tank the floor, replace all the pipes and just look to find the leak once and for all. He said there was no point as with pipework was all good, just some minor sealant gaps. He sprayed the overflow with the shower to demonstrate that it was fine.
The science bit:
I did my own experiments. I filled the bath and emptied it. No leak.
I filled the bath up to the overflow and water poured out of the pipe, so he sealed it.
Conclusion??
So there was an issue with the overflow connection, but I can’t see how enough water goes down an overflow from a shallow bath to cause such a leak. Or does it?
The overflow pipe has been resealed before. How come it keeps failing?
Could there be another issue connected to the emptying of the bath that would be intermittent?
I really, really don’t want it to leak again. What could I do? Is there any super absorbent stuff I can put under the bath that flashes red and calls the plumber when it gets wet? I bought some little leak detectors from Amazon, but don’t know how effective they will be.
Please let me have your thoughts. I hate conflict and am feeling sick.
xx
Background:
- It’s sporadic – sometimes nothing for weeks
- Sometimes it’s a bit (damp/few drips) and sometimes a lot (water running through light-fitting).
- Doesn’t last long before it tails off - 15/30 minutes or so ….although not totally sure as it’s often unnoticed (it’s in a stairwell in an office that is empty at weekends).
The science bit:
Conclusion??
xx
