We think we have some uninvited guests of some sort but can't quite figure out what.
We've a standard loft conversion at the top of our standard vitorian terrace. So pretty much no loft, just a foot square triangle that boxes in the bracket holding the old chimney pot above (the rest of the chimney breast gone).
From this little area we've started to notice a scratching or buzzing or rustling kind of noise - through the layers of plasterboard & skim the sounds is deadend a bit so could be either of these 3. The sound seems confined to this area, not all across the rest of the loft conversion's ceiling (which is about 6 inches of void stuffed with the usual insulation material and a bunch of downlights). So we figure that 'whatever it is' has come down the disused & capped off chimney.
Using a webcam on a stick we've tried to have a look and can only see a few small dark areas which could either be holes or simply missing pointing (the webcams not that good and we dont have a ladder to get up there ourselves).
The pictures show the few small dark gaps/holes:
(ours is the short capped pot on the left)
(our is the one on the right of the pair in the foreground in this one)
The lack of a large enough hole means we dont think it's pigeons; And 2 floors I would think that rules out foxes too. Leaving mice, rates & insects. Can/do mice and rats climb vertically up 3 storeys (read) or 2 storeys (front)????
Any suggestions what this could be?
I'm intending ringing the LA Pest Control tomorrow but hoping I can sound a bit less clueless by then !!!
